Many small blocks are weak at topend oiling,take out the restricters and check all the oil passages including the bolt that has the oil supply and shaft for restriction.Make sure pushrod cup height is correct to catch the oil from the supply hole.Since you havent mentioned the type of cam,lifters and rockers there can be other issues and corrections.
