If your car requires a cage, then a window net is also required, no matter what the ET is.
Are you sure on that? I'd ask the tech guy at your track!
http://www.northeastdragracing.com/showthread.php?9850-Window-net
Re: Window net
Originally Posted by Top452
If you are running in the 10s do you need a window net if the car has a cage.
Let's clear this up
Window nets you do not need a window net if you run 10.0 or slower
If you run 135 mph you need one.
Window nets do not have to be replaced if thay are ribbon type as long as there in good shape , the fish net ones have to be replaced every two years .
Pro classes must replace them in two years.
I hope this helps every one to understand this rule.
Buddy Scurto
Tech Director
NED
