Re: Carter 500's, can this mess be fixed & if so worth it?
[Re: gdonovan]
#1437054
08/01/13 11:41 PM
08/01/13 11:41 PM
Posts: 4,395 The Pale Blue Dot
Skeptic
The Pale Blue Dot
You listed the wrong carb, look up a 500 CFM AFB (performer series).
"Comes with: Metering Jets - Primary .086, Secondary .095; Metering Rods - .065 x .052; Step-Up Spring - orange (5" Hg)"
This is incorrect, I spent hours last night chasing my tail due to it.
The listing I posted is for the dual quad calibrations, if you aren't using them in that configuration, my bad. The performer and thunder avs carbs show the same single quad calibrations. In the Edelbrock carbs they are only different in the secondary actuation. That is not the case in the original AFB/AVS carbs. I found this out the hard way. Anyway, good luck with your project. ![](/ubbthreads/images/graemlins/thumbs.gif)
Entire Thread
gdonovan
05/16/13 12:19 AM
gdonovan
05/16/13 12:20 AM
RapidRobert
05/16/13 01:01 AM
OzHemi
05/16/13 01:05 AM
hulmule
05/16/13 01:09 AM
gdonovan
05/16/13 10:32 AM
quickd100
05/16/13 11:00 AM
floridian
05/16/13 12:40 PM
dogdays
05/16/13 04:26 PM
ScottSmith_Harms
05/16/13 04:55 PM
JohnRR
05/16/13 05:00 PM
ScottSmith_Harms
05/16/13 05:12 PM
gdonovan
05/16/13 05:29 PM
ScottSmith_Harms
05/16/13 05:52 PM
62maxwgn
05/16/13 05:58 PM
gdonovan
05/17/13 01:22 AM
gdonovan
05/17/13 01:23 AM
ScottSmith_Harms
05/17/13 04:34 AM
ScottSmith_Harms
05/17/13 04:35 AM
ScottSmith_Harms
05/17/13 04:36 AM
62maxwgn
05/17/13 02:20 PM
ScottSmith_Harms
05/17/13 02:42 PM
62maxwgn
05/17/13 03:15 PM
RapidRobert
05/17/13 04:10 PM
gdonovan
05/17/13 04:22 PM
62maxwgn
05/17/13 05:38 PM
Dodge-N-Shelby
05/17/13 10:17 PM
gdonovan
05/17/13 11:46 PM
gdonovan
05/25/13 01:48 AM
gdonovan
05/25/13 01:49 AM
Skeptic
08/01/13 01:41 PM
gdonovan
08/01/13 02:07 PM
gdonovan
05/17/13 09:49 AM
gdonovan
07/31/13 08:55 AM
Skeptic
07/31/13 08:34 PM
gdonovan
07/31/13 09:33 PM
Skeptic
07/31/13 10:21 PM
gdonovan
08/01/13 03:06 AM
Skeptic
08/01/13 01:37 PM
gdonovan
08/01/13 02:01 PM
Skeptic
08/02/13 03:41 AM
gdonovan
08/02/13 09:16 AM
Skeptic
08/02/13 07:05 PM
a12superbee
08/02/13 09:16 PM
gdonovan
08/02/13 11:14 PM
Skeptic
09/05/13 03:12 AM
gdonovan
09/05/13 10:52 AM
