I put cardboard under the car, and not a drop of oik.I doubt I broke a ring,since it never burned a drop before I pulled the intake it would make more sense to believe I botched the install. Gaskets should be here this AM,but probably have to wait till my next day off to try again. Thinking it's probably only leaking under pressure,and it's fresh oil,hence the clean plugs. I only used permatex around the water ports,and probably laid it on too thick,an I bet it caused distortion.
