Quote: I think there is a little confusion here, The Op states his aircleaner won't sit on the carb,
So if i am correct he wants to put a spacer on top of the carb not under.
From what he was saying, he was looking at putting a spacer under the carb to raise the carb and air cleaner ... like its hitting the intake because he asked if it would change the performance
I agree , he wouldn't be concerned with the spacer hurting performance if he put it on top of the carb ????
