I checked all the plug wires to make sure there wasnt a bad one and it was miss firing but everything lookd great.
Ok, before you start tearing stuff apart,...just check the firing order, confirm the correct wires on the correct plugs and terminals,...seen this before, misfire masked as a vibration issue at idle, fine when you get on it,(so it seems) but crappy at idle or low speed cruise...
