the blocker pin is for the 4th gear lock out, if your running a 3 speed you dont have a 4th position. the other pin iirc is because the spacing on some trans between park and neutral is longer so its a compensator...where it may feel like there is 2 position between park and neutral on the shifter...I just installed one, and ill tell you the directions suck!!! I read it 10 times and fiddled with it until I figured it out.
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd
74 gremlin x 360
65 mustang 347
70 coronet R/T 440
03 Mach 1
