Dash frame, steering column, ashtray & windshield/headliner garnish had a flat "suede" textured finish similar to 600-grit sandpaper; DuPont code 9612LH "Majesty Blue". A-pillar, back glass garnish, console were a lower gloss, 9643LH Baltic Blue Metallic. Door/quarter metal, 4983L Baltic Blue Metallic. These are all original Dupont codes, but R-M was also a supplier and there are Ditzler codes as well. Defroster ducts BTW were not suede but low-gloss (molded in color); not an exact match to the dash color but close. Interior gloss was generally a bit less than the exterior paint on the door/quarter metal.
