Typically if you buy Quick struts they are easy to change.I did some on earlier Caravans etc.3 nuts on top,some have a cover over them.Then usually 2 bolts and possibly a brake line attached.Some the sway link and almost all the tie rod end.I can usually R&R a set in less than 1/2 hour on a rack.Rocky
Chrysler Firepower
