I hope you dialed in that bell housing. I just dialed a friends blown 55 chev with that quick time bell and I had to get .014 offset dowels to get it in specs. That tranny wont shift right if you have clutch drag.
everything is in the mock up stages right now, no tunnel modifications and it looks like ill be able to flip my shifter around to the "middle" position for a good shifter location.
im not looking forward to the bellhousing spec but it has to be done
