You could bolt in a 5.2 Magnum (late model 318) with a intake change... Motor mounts bolt up, trans bolts up, exhaust bolts up, either an electric fuel pump or change to the early timing cover & add the pump eccentric.. It does require a aftermarket intake..
"The Armies of our ancestors were lucky, in that they were not trailed by a second army of pencil pushers."
