I'd start with carefull measureing to see if 1.5" per side change plus the backspace change will clear the springs on the inside & the fender on the outside. ie a p225 tire the 225 is the sidewall bulge to sidewall bulge width in millimeters. divide 25.4 into that to get it in SAE (inches) & that dimention may help you in your clearance checks
