remove the old studs by cutting the "Knurelled" part off, Usually a holesaw with a 1/2" ID works for this operation. drive the out. I preferr pressing in new studs instead of pulling them in with washers and a lugnut. Less stress on the threaded portion that way.. Id install all the old studs incase the old studs have been stressed...
I am truckless..
