Thanks guys.
That's a 1-year only piece Jamie.
I wonder if Ma ever did this A38-style in 75? Haven't found one.
I like the look better than 76 up units. Tach dash from a 75 Cordoba. Took some time to find a 75-only certified speedo
Was filthy but dry inside, and needs to be tested yet. Already swapped some gauges with NOS. The upper bezel is later Cordoba - protection only at this point.
76 and later tachs wire through the PCB, thus the housing and board are different. Who woulda known?
Tried a 75 Cordoba upper and lower bezel as well with the fakey burled woodgrain and inlays. Too busy IMHO. If you're interested in selling the RR halves, PM me.
Still pulling together misc body and int items, so if you know of parts or a car,
A38s rule Boys
