are you removing the connectors from the bulk head connector ?
It was time consuming but I made myself a good drawing of what went where and removed them from the connector and cleaned them.
X2 but I'd consider going ahead & replacing them. NAPA 725145-female and 725147-male. It ain't bad once you get the hang of R&R ing them & recrimp/solder em & that's such a problem area I'd just as soon do it right & be done with it . I'm sure one of the cleaners mentioned would work well but it'd be a pain to do em where they are located as it not like it's an item you can remove & soak on your bench. . Holler what/how the cleaner you pick works for you.
