Since Alaskan T/A has the kick panels covered, the pieces you currently show in the kick panels should be installed in the dash structure (Just above the kick panels) you'll see them in the upper corners of the photo's I have attached. I can outline them if you need but think you'll find it pretty self explanatory, if not, let me know.
Doing my insulation now. The REM kick-panel kit I got several years ago has 3 pieces; the 2 larger pieces which is self explanatory, and the piece for the backside of driver-side kick panel, not one the for the passenger side. Any ideas where I can get the passenger side piece? How were they secured to the backside of the kick-panels? Also, does anyone know if the two oddly shaped pieces that go "above the kick panels" (as AAR#2 pictured) are being reproduced? Thanks for the help.
