Try soaking it in carb cleaner or solvent, Evaoporust can also help since it disolves away rust. I use various chemicals and a sonic cleaner and I can get most free, but sometimes they need to be cut out in pieces. If you need yours restored I don't charge extra for such things (even though it can add a ton of work to the job).
Diesel fuel works too but nothing like a little heat!!
