" When I've had sets that didnt match I usually air the smaller tire up to around 30 psi for about 15 minutes. If you can set it out in the warm sunshine it will help. I guess you could send them back but I've always streched them and they worked fine. "
You would be amazed how quick and easy this is to do.
Mike
