Not easily, you'll need 4.5 or 5 inch BS on an 8 inch wheel with the springs moved like that, but you still have the problem with the inner and outer qtr. You could bend the lip up and be real carfull plus do some trimming on the inside. Keep in mind that is a tall tire for an A body. It'll be really tight.
