I know that the original clutch for my 1970 440 six pack Super Bee was the scalloped design clutch with a 10.95" disc.
Any reason to not use the Centerforce dual friction 10.5" clutch behind a basically stock 440 six pack? Probably will make 450hp max after the rebuild?
Stock flywheel and bellhousing...
What do you 4 speed guys use??
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
