yea a little, you can tell the difference.
Tony, are these the summit ones you are talking about? are they straight through like the bullets? Or is there material inside of them? They are cheaper than comparable sized bullets, and I wanted to pull the trigger on them but was not sure if they are the same design or if they will choke up power
yes and yes, they are straight through. glass packs, they are loud but you can tell the difference
