I'm using the factory 318 poly cable that came in my 64. No problem. Using a mighty Demon carb.
The adjustable throttle bracket from ar engineering might be a good idea.
I made a bracket, by modifing one froma a smog 400 motor. A bit of heat, and some bending, and it worked too.
