Quote: They can and should do that, but I bet some of them do not, especially if there is a young guy running the machine who thinks there is no value in checking a solid axle rear. The four wheel alignment can tell you thrust angles and camber angles of the rear, which aren't bad things to know.
So it would show if the axle housing is bent also?
