Quote: Do yourself a favor and actually test the fuel pressure with a guage. Knowing what the actual pressure reading is the correct way to diagnose the problem. To little pressure as well as to much fuel pressure will both cause a host of problems.
Also check your steel fuel line from the tank for rust. You may not see/smell anything, but a tiny pin-hole will defeat your pump. DAMHIK...
