A/C also doesn't work
One time, on my 92, the AC stopped working and when I went to put the windows down, they didn't work either. I don't know about the cruise control and overdrive because I only drove it to a shop less than a mile up the road to be fixed. Turned out to be the ignition switch. I have no idea if this could be your problem, I'm just throwing it out there because of the AC issue you mentioned.
