Welp, laid a plank across the fenders, used a 1/4 Allen wrench to remove the crank sensor. Thanks to you two helping it only took about 3 minutes to change. But truck still doesn't start. After all the rain we had is when it quit running, threw a p0138 code so I've since then changed both o2 sensors, cap, rotor, coil, cam sensor and crank sensor, still nothing. Getting good fuel pressure. Was gonna check plugs, and idle air when I get home. Working 12-14 hours a day so not much time to work on it
![](/ubbthreads/images/graemlins/frown.gif)
