I forgot while the box is out make sure the valve arm is moving nice and free.They get corroded and wont switch heat setting or they will bend the cable.I lube mine regulary.Only thing is I bent the h--l out of the cable before I found it was stuck.Now I just crawl under the dash and change it by hand.Rocky
Chrysler Firepower
