I usually put a very thin layer of grease on the ball so it does not squeak while turning at low speeds. For some reason the lava rock dust out here is like chalk and makes brakes, etc. squeak like crazy at times. Otherwise I don't think the parts mating together are moving fast enough, far enough, often enough to wear themselves out unless under an unusually high load.
