I haven't used a 727 in years but is there any reason why studs are not to use studs and lock nuts on use lock wire???
The clearance between the bolt head and block... even
with bolts the head thickness is pretty thin for clearance...
the welds on that conv look like they didnt penetrate
at all(like the weld was sitting on the top of the
metal... it could be the heat affected zone I'm
looking at
