16.5s are available but very limited on sizes unless your lifting it for pudding than Super swamper has Several.
The 94 up wheels for dodge have a different offset and can cause tires to rub. Same with ford rims offset is diff. I had ford rims with 235/85 16s and close to lock the tires rubbed
