going to open the front of the bulge hood up to copy a viper !! THE car had a brand new go wing on it when I bought it . THE good one, building my own rear window louvers out of 18 gauge sheet metal!! The door gills step down from the fenders,Everything so far un bolts , the 68 rear bumper will unbolt from the 74 bumper bracketS but the tailight panel will be welded like a 1968 ..
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
