My buddies Demon. I love Demons as I think they are one of the best looking A-bodies. And why use a bigblock in one when you have these smallblock strokers that run like a bigblock anyway. If I had the moola I would have me a Demon for my A-body car. Ron
i'm a big block believer... with aluminum heads/intake they weigh the same as the original all-iron 340's. and for a small block to get the same power as a 440, 451, 470, 500 etc you need to spin a lot more rpms, have more converter, etc. basically you put a lot more stress on the bottom end for the same results. not only that, BB aluminum heads flow better out of the box than big dollar ported SB heads.
I agree with you as you are right. I am a bigblock guy myself but I am very impressed at how well the smallblock strokers run and figure either one the big or smallblock should work good in an A-body. Ron
