Just get a D60 and call it good. But it you debt plan on beating the not out of it an 80-93 D44hd from a 3/4 1-ton will work just fine. 75-79 are Full time axles with bad bearing design. No Lockout But you can swap outer shaft and knuckle out on a full time with a part time Pics
I didn't buy it yet. Was exploring the options with a drum brake front end. You will never find me putting a 44 under anything, especially if equipped with a real axle originally. I've seen them destroyed by a warmed over 360 and a stick. I've personally.destroyed one with a bone stock '69 440 and a stick. 44's are for 1/2 tons and automatic transmissions...
Then you don't want a closed knuckle D70. Tracta Steering Joints aren't really your friends here. ![](/ubbthreads/images/graemlins/rolleyes.gif)
Ouch
Noted! ![](/ubbthreads/images/graemlins/shock.gif)
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
