make sure to use the M-400 bearing with snap ring like DrDiff sells.you can leave it in with the M-400 bearing.
remove it if you have the mopar bearings with crimped on retainer. those will pre-load the bearings = failure.
if it has buttons you can remove without a teardown, then I would remove them anyways.
