On 3/4 and 1 ton axles the wheel bearings are lubed with gear oil from the diff. Pulling the axles will let the oil run out of housing and not to the bearings. Shoving a rag in the end stops the leaking and lub getting to the bearings. The hub flanges must be capped as if the axles are still in to keep bearings lubed.
