I've got Simpson 5 way cam lock belts in both of my cars, one has the cam lock on the right hand lap belt and the other set has the lock on the crotch belt. Is there a way to change the lock position with out sending it back to Simpsom ?
Not that I know of.. as soon as you tamper with it you
void the SFI spec and if the tech sees its been tampered
with you wont pass.... I'm not sure about Simpson
but I dont think they re-web
