remove the vac booster and use the foam gasket as a template to make a metal plate drilled for a 2 bolt alum MC
the manaul brake rod is 7" long and you can get the adjustable brake rod.
all I did was order up a MC for a 79 ramcharger,used the stock prop valve,with 11x2.5 rear drums,large wheel cyls.
spoon up the rears and it has a nice firm pedle and stops great with the 440 up front on my 88 truck.
here is a stock rod and plate from a manual brake truck,this is the set up I gave to John.
