We use a gas powered golf cart with a push bar on front that has two 4 wheeler tires one on each side to match up to the rear tires on the dragster,works well except on tight turns.If there are a lot of tight turns we use the tow strap.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
