Well, today while driving the car the trans finally let go... 1-2 shift let out a nice big bang and that was all she wrote.... no forward gears or reverse..... but PARK still works
O.K. now what... do I look for a small block 727 to build or do I try and fix this 904 (999)???????
I do like having the 2.74 low gear but maybe I should just settle for the 727 and get a higher stqall converter??? TBF
No forward tells me something inside the trans broke ( obviously ) , but no reverse ? it's either a broken input shaft , the splines on the front of the output shaft or the pump , drop the pan and see whats in there ...
