My 65 barracuda has 275's on it and all I had to do was move the springs under the rail and push the floorpan/trunk/wheel tub ext over to be flush with the frame rail.I use a 15x7 wheel with a 4-3/4 neg offset.I actually have plenty of clearance.
410 pump gas solis flat tappet cam 10.95 so far
