24 is the mode door actuator failure.
It means you're stuck with air blasting out of the current vents.
The ATC and manual AC systems had different actuators. If I recall correctly, replacing them requires a dashectomy.
The actuator I needed was discontinued.
We are brothers and sisters doing time on the planet for better or worse. I'll take the better, if you don't mind.
- Stu Harmon
