I found the black horn wire that attached to the clip near the ring under the cap, that it?
Yes. There's 3 terminals on the horn relay on the firewall. www.mymopar.com will have the colors for you. (1) One terminal should be hot all the time (see if it is). (2) Jump fire to the second wire that goes forward to the horns & they will honk unless that circuit has an open or both horns are bad (not likely) or both horns have lost their ground (not likely). (3) the third wire is the one mentioned & goes back to the horn button so jump that terminal to ground & see if it honks & if so check each connection from that terminal on the relay back to the horn button (bulkhead/column harness/horn button itself). Seperately the column is grounded to the frame with a length of black wire several inches long with eyelet terminals on each end & is used on the bracket that bolts the column up to the dash.
