Re: Door lock cylinders frozen. How do I unstick them?
[Re: B5 Bee]
#1362577
01/01/13 06:44 PM
01/01/13 06:44 PM
Posts: 21,845 Kirkland, Washington
Pacnorthcuda
Besides my occasionally used auto door locks, I have the same problem with seldom used home door locks.
You may be able to get them to turn with regular lubricating oil. If you use a penetrating oil first, once loose, give them a shot of lubricating oil. I've been using PB50 lubricant, same company that makes PB Blaster penetrant. BTW, WD40 is not a good penetrant or lubricant, use something better for both needs.
Actually WD40 is great for frozen door locks . "WD" stands for "water displacing" it literally moves it out of the way.
