It will work fine but you have to keep the surface wet for the acid to do its job. Use a garden sprayer, spray bottle, brush or whatever. The lighter the rust the faster it works. Also keep in mind the stuff is a "converter" not a "remover" so don't expect the end result to be shiny bare metal, the converted rust will likely be black.
