the repo rear rubber bumper from Gene Gregory is very nice, I think compared to an original it would be very hard to tell the difference once painted an installed.
Good luck finding an original if you are set on that. Even with a "mint" original, if it has seen any rain in it's life chances are the rear studs are starting to rust and separate from the core.
Can't tell you about the Cuda bumper but the Gene Gregory Challenger bumper is about 1.25" wider that an OE Elastomeric bumper... Taking a chop saw to both ends of aa brand new bumper is scary....
This is exactly what om talking about!
Will not try to cut a new bumper and then try to fix it up..Im sure i will make a mess with it ![](/ubbthreads/images/graemlins/rant.gif)
ErikR
http://www.garaget.org/mypage/gallery.php?user=106330&album=43470
