What do you have against switching to an aluminum piece? Much easier to repair. We split a cylinder on an older mega block on the dyno, switched to an aluminum indy and actually picked up around 25 HP. Nothing else changed except the rings. 1275 HP predator heads.
A833 4-speeds, parts & services
http://www.brewersperformance.com/
