Re: aluminum master cylinder recomendation
[Re: Blue Dodge Bob]
#1345385
12/07/12 09:31 PM
12/07/12 09:31 PM
Looks like you're using a 1 1/8 bore mc on a 63 Dodge B body which is comparable to my 64'( yours is a little lighter probably).
Do you know if there is that much difference pressure wise,etc., between bore sizes; 1 1/32" vs 1 1/16" vs 1 1/8" ?
From previous comments here on the board, the Diplomat masters aren't nearly as firm at the pedal as the truck ones are. It's livable but firmer than I would prefer.
