I am putting '96 magnum heads on this old 318 so I wanted to be sure they were the right head bolts.
I believe the mags take a unique bolt (P4876759). I have a set for a Magnum swap also & I'm not sure if they are torque to yield or not. You have used ones that you were considering reusing? If not TTY then the thread gauge check sounds excellent & I'd just lightly wire brush em clean & good visual for nicks that would screw up your torque readings.
magnum INTAKE bolts are supposed to be TTY, IIRC, not the head bolts. and there's 1 or 2 that are different length for an LA, so LA head bolts won't work.
I reused mag head bolts when I put mag heads on an LA 318 roller, didn't have any problems.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
