I did the same for my '73 Roadrunner, and it was well worth it! My best advice is measure a LOT, and make sure that when the shifter is mounted to the back bracket, that the linkage rod fits in the front bracket before you tack weld everything. Just basically put the brackets as close to where they came off of the other one. Good luck!
