I presume 318 with the fender ESC. Call me ignorant, but I'm pretty sure even the electronic spark control (ESC) engines had a ballast and a ECM. Its got 2 pigtails coming out of the distributor, right?
http://ramchargercentral.com/media/?sa=item;in=1061There is a specific way to bypass the ESC computer and detailed in the MP instructions that come with the kit. However, its cheaper to source the parts from a JY rather than buying the kit.
The carb on that should be a 2280/6280. Consider the idle solenoid for inspection/broken wires as well as choke function.
